i get an Unrecognized service for that. So i assume not installed.
any further ideas?
just checked with KnownHost and was told the only thing is: iptables
ran command: /sbin/service iptables stop
but to no prevail
yep that is what im doing . just get a
unable to connect to host: Connection refused (10061)
address: 65.99.213.102:1
rm -rf /tmp/.X1*
vncserver
I believe VNC uses port 5900. I will increment based on which screen you are using. So screen 1 would be 5901 etc.
Has anyone tried this with the Xfce desktop? A little lighter on resources then KDE but would provide about the same functionality.
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/server1.500servers.net:1
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
Xvnc version 4.0 - built Jan 17 2007 14:52:53
Underlying X server release 60801000, The X.Org Foundation
Thu Jun 14 23:27:59 2007
vncext: VNC extension running!
vncext: Listening for VNC connections on port 5901
vncext: Listening for HTTP connections on port 5801
vncext: created VNC server for screen 0
error opening security policy file /usr/X11R6/lib/X11/xserver/SecurityPolicy
Could not init font path element /usr/X11R6/lib/X11/fonts/misc/, removing from $
Could not init font path element /usr/X11R6/lib/X11/fonts/TTF/, removing from l$
Could not init font path element /usr/X11R6/lib/X11/fonts/Type1/, removing from$
Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing from l$
Could not init font path element /usr/X11R6/lib/X11/fonts/75dpi/, removing from$
What are the benefits in getting a GUI when you can administer the server through a command line?
Does Centos has an admin interface in GUI that will make it easier to add accounts, create domains, or mysql databases that will alleviate the need to have, say, webmin or cpanel?
From a Unix newbie...
